1999 Honda Civic issues when A/C is on
AABDU3
Noises problem
1999 Honda Civic 4 cyl Front Wheel Drive 126000 miles
I just bought a used 1999 civic lx, when I tested it at the seller's everything was fine. but later after I started driving a little bit I found that when the A/C is turned on the engine makes noises, a squeak or whistle like and increases as I accelerate. also the engine vibrates more and the driving wheel when A/C is on. I have no major experience but I suspect that this could be a bulley or belt problem with the a/c compressor?! other than that the A/C works really fine.
Jul 7, 2010 at 2:40 AM
F4I_GUY
  • 3,302 POSTS
The a/c idler pulley is a very common failing item on your vehicle. I'd recommend you taking a look at that first as well as your belt.
Jul 7, 2010 at 4:00 AM
GRANTSPASS23
My honda is doing that too... I had to replace the driver side fan cause is was no longer working which was making the compressor lock up... No it will squeal or whistle when I accelerate... A mechanic told me I needed a new compressor... 300 dollars... 100 for a mechanic to put it in... I found one online for 190 though... Also check and see if you have a broken motor mount... That will cause shaking...
Jul 9, 2010 at 4:35 PM
