1999 Honda Civic Heater fan
1999 HONDA CIVIC
73,000 MILES • 4 CYL • 2WD • MANUAL
PAUL90
I just would like to seek your help because when my heater fan is turned on settings 1 & 2 (low speed), there is no air coming out from the vents and it seems the fan is not working, but when turned to settings 3 & 4 (higher speed), the fan is working.
Nov 17, 2008 at 4:53 AM
KHLOW2008
  • 41,814 POSTS
Hi paul90,
Check the blower motor resistor, most probably the 1st and 2nd speed mode is faulty.
Nov 21, 2008 at 12:28 AM
PAUL90
[quote:94e0dfe7da="KHLow2008"]Hi paul90,
Thank you for your help. I took out the resistor plate and found a broken connection for the two resistors maybe due to wear and tear. I bought a new one from Honda dealer at £29 incl. vat.
Check the blower motor resistor, most probably the 1st and 2nd speed mode is faulty.[/quote:94e0dfe7da]
Nov 24, 2008 at 6:09 PM
