1999 Honda Civic Fuel leak
170,000 MILES • 4 CYL • 2WD • MANUAL
CHIEFTAIN34
I've noticed a fuel leak from what I believe to be the fuel rail. It is pretty significant. I have just had a lot of work done including replacing the head gasket, battery, and alternator. What could cause this?
Sep 5, 2010 at 3:58 PM
KHLOW2008
  • 41,812 POSTS
Hi chieftain34,
Fuel leaks at the fuel rail are mostly due to bad injector O rings. As fuel in the rails is under pressure, any weak O rings would result in a substantial amount of leakages.
Sep 8, 2010 at 5:45 AM
