I RECENTLY HAD MY CHECK ENGINE LIGHT COME ON AND PEP BOYS GAVE ME A CODE OF P0135 WHICH IS MORE THAN LIKELY AN O2 SENSOR. I'M THINKING I SHOULD REPLACE THE DOWNSTREAM SENSOR BUT 2 WEEKS AGO AT AROUND 5,000 MILES MY OIL LIGHT CAME ON AND I WAS 3 QUARTS LOW WHICH WAS ODD CAUSE I DONT HAVE A LEAK AND THE CAR ONLY HAS 70,000 ON IT. MY QUESTION IS DO YOU THINK IT COULD BE THAT I MIGHT HAVE A COMPRESSION PROBLEM AND SHOULD I CHANGE THE O2 SENSOR ANYWAYS?
THANKS
GVILLECR
THANKS
GVILLECR
Feb 2, 2007 at 1:39 PM
