1999 Honda Civic CLUTCH OIL ON TIRES
89,000 MILES • 4 CYL • 4WD • MANUAL
LILREDHONDA
I purchased a used honda for my 16 year old daughter. We've driven a few mths and now I have a few concerns.
1. We are having problems putting it in first gear (especialy when not warmed up). It seems stiff and doesn't want to go. Does it need a new clutch? If so, what should i expect to pay?
2. Looks like oil is spraying on front driver tire...however oil isn't going low...there is a slight squeek when we go over a small bump but not sure it these are related. thoughts? Expensive?
3. finally, are these normal wear and tear for the age and miles...or should i be concerned i've puchased a money pit...I do have apt at a local dealer next week but being a gal I don't want to get taken so trying to educate myself before hand. Really appreciate any feedback or suggestions you can share. Thanks!
Aug 16, 2008 at 3:26 PM
KHLOW2008
  • 41,812 POSTS
Hi lilredhonda,
1. Stiff gear shift could be due to linkages needing some lubrications. If gears are crashing when shifting, then it might be the clutch. Get the trans oil changed, might improve the gear shifting smoothness.
2. The oil spraying on driver's tire could be brake fluid and you need to check for a leaking brake hose at tire.
These are wear and tear items with some giving way due to age but nothing major to worry about.
Once repaired, it should last a long while.
Aug 16, 2008 at 7:58 PM
