1999 Honda Civic Check engine light
76,000 MILES • 4 CYL • FWD • MANUAL
JASONTHEMASON
Last week my check engine light came on. It seems that when the car warms up, I have a loss of power and an uneven idle, as if it were no longer firing on all cylinders. I recently had my 75,000 mile checkup so all the plugs and filters are new. Yesterday the engine light started flashing and then the engine died. I took it to a mechanic. He thinks it's just the battery (original) or possibly the alternator. I'm thinking it's more serious than that and may be the fuel injection or pump, as the battery wouldn't have anything to do with the engine running unevenly...would it? After reading through other posts I realize it could be a number of things but hoping you can help me pinpoint the problem. Many thanks.
Feb 11, 2008 at 12:10 AM
MERLIN2021
  • 17,250 POSTS
If you have a battery with less than the systems required voltage, usually 9volts minimum, the engine management does not operate correctly, and can't even be properly tested! Make sure Battery and charging system are up to snuff before you continue diagnostics...
Feb 11, 2008 at 12:14 AM
