1999 Honda Civic a/c control
55,000 MILES • V12 • 2WD • AUTOMATIC
ARPAG
Hi, my honda 99 civic vtec automatic does'nt have a problem but just suddenly when the aircon is on, the idling goes down to a very low level, about 500 rpm and very erratic, and there's an alternating clicking sound, from the compressor. The engine then dies. Could it be the a/c idle control? If so, how can I correct it? Can it be just cleaned and the problem is solved? Turning off the aircon, the engine goes back to its former condition. Thanks
Nov 6, 2008 at 10:42 AM
KHLOW2008
  • 41,812 POSTS
Hi arpag,
You have a problem with the idle controls and most probably the Idle Air Control valve and throttle body needs a good cleanup. A can of carb cleaner spray could do the job.
Nov 19, 2008 at 1:57 AM
