1999 Honda Civic
BVALDEZ81
  • 1999 HONDA CIVIC
1999 Honda Civic 4 cyl Two Wheel Drive
My car is running on 3 cylinders only, instead of 4. I have done the spark plug test and located the bad cylinder. I have changed the waterpump, thermostat, timing belt, spark plugs, spark plug wires, a fan sensor. I want to know what could still be causing my problem? At first it would die after I would put it into drive and accelerate, now I having a hard time even getting it to start. What could be the issue? I have also used the Seafoam fuel treatment. Could it be the fuel filter?
Sunday, September 5th, 2010 AT 2:13 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check engine compression that will tell if problem is internal engine fault.
Let me know
Thanks for donate
Sunday, September 5th, 2010 AT 2:24 PM
BVALDEZ81
Ok how do I check engine compression? Ur post wasnt much help lol
Sunday, September 5th, 2010 AT 2:42 PM
DOCFIXIT
  • 18,828 POSTS
Remove plugs get a compression gague screw into #3 plug crank what is pressure reading. It is that simple
Sunday, September 5th, 2010 AT 4:23 PM
