1999 Honda Civic
RACHELLE3
  • 1999 HONDA CIVIC
Engine Mechanical problem
1999 Honda Civic 6 cyl Front Wheel Drive Automatic
The car was making a clicking noise and then the belts in the engine stopped turning?
Friday, July 16th, 2010 AT 1:38 PM
KHLOW2008
  • 41,814 POSTS
Hi rachelle3,
Do you mean the engine is running but the belt do not?
Or you are trying to crank the engine but it does not crank up?
Saturday, July 17th, 2010 AT 6:11 PM
RACHELLE3
Yes the engine starts but the belts don't turn.
Saturday, July 17th, 2010 AT 11:03 PM
KHLOW2008
  • 41,814 POSTS
All the belts or only specific ones not moving?
You have a seized bearing somewhere, alternator, compressor or idler pulley.
Check if the lower crankshaft pulley is moving. There is a possibility the lower bolt has broken off as you mentioned clicking noises.
Sunday, July 18th, 2010 AT 2:34 AM
RACHELLE3
Two belts and neither one moves.
Sunday, July 18th, 2010 AT 12:39 PM
KHLOW2008
  • 41,814 POSTS
Check the crank pulley central bolt to see if it is loose or missing. I believe the crank bolt is broken. Do not attempt to start engine now. If the timing belt skips, it is going to damage the engine.
Sunday, July 18th, 2010 AT 2:45 PM
