1999 Honda Civic
ACHIRAVURI
  • 1999 HONDA CIVIC
Transmission problem
1999 Honda Civic 4 cyl Two Wheel Drive Manual
I had to replace my transmission because it was going out. Now, after doing the swap, I sometimes can't get into first gear when the car is running. If the car isn't running, I can shift into first gear everytime. Also, there seems to some noise coming from the clutch area that wasn't there before. Finally, I don't know if this will help, but my speedometer jumps around, not to drastic, make up and down by 2 mph.
Wednesday, July 15th, 2009 AT 2:46 PM
F4I_GUY
  • 3,302 POSTS
Sounds like you have a hydraulic clutch issue (why you can't get it into first) Check the fluid, if it is low, you have a leak either at the slave cylinder or master cylinder
Wednesday, July 15th, 2009 AT 3:42 PM
ACHIRAVURI
I checked my fluid level on master cylinder and it was fine, but is it possible that the slave cylinder is still messed up?
Wednesday, July 15th, 2009 AT 3:44 PM
