HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Climate Control
Heater
Heater Core
SPONSORED LINKS
1999 Honda Civic
AMANDAS.
MEMBER
1999 HONDA CIVIC
Heater problem
1999 Honda Civic 4 cyl Automatic
I am trying to get some info. On how to change my heater core and if I could get some pictures. Also what else I could do if it is leaking.
Thursday, June 18th, 2009 AT 12:05 PM
F4I_GUY
MECHANIC
This is a lengthy process. Best thing to do is purchase a manual so that you have it inside the car with you while you are working on it.
You have to remove the dash out, to fully explain it to you it would take an hour!
SPONSORED LINKS
Thursday, June 18th, 2009 AT 6:00 PM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
1988 Honda Civic What Else Besides The Heater Core?
I Can Smell Antifreeze In The Car. I Took The Heater Core Out And Had It Tested But It Doesn't Leak. What Else Could Be Causing The Smell...
Asked by
j99
1988
HONDA CIVIC
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
Heater Core Leaking?
I Have A '95 Honda Civic Coupe Dx At 212,700 Kms. Recently While Driving, I Noticed Coolant Leaking Onto The Passenger Floor Mat While I...
Asked by
alisondrain
HONDA CIVIC
1991 Honda Civic Heater Core
I Am Needing Advice On A Heating Issue In My Car, The Problem Is My Car Doesnt Produce Enogh Heat, When The Car Is Sitting And Warming Up...
Asked by
dmoney19
1 ANSWER
1991
HONDA CIVIC
2004 Honda Civic Heater Core?
Car Is Heating Up No Hot Air Coming From Heater
Asked by
donrooley
1 ANSWER
2004
HONDA CIVIC
95 Honda Civic Si
How The Heater Core Connected To Heater Valve? Where Is The Heater Line Located? Is There Any Way I Can Take Out The Heater Core Or Valve...
Asked by
ays
1 ANSWER
1995
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Heater Hose Replacement
Heater Hose Replacement Chevrolet Camaro
Heater Not Working
Online car repair manuals
