1999 Civic LX Head Gasket
LYDIADZD
1. 1999 Honda Civic LX, 1.6L
2. Odometer: 225,000
3. Automatic Transmission
4. Sounds: A slight knocking/rubbing sound, which sounds like it’s coming from the left front wheel. I’ve had it checked by the garage that did my brakes recently, and been told that they cannot find anything.
5. Fluids: I have been using 5/30 full synthetic, with regular oil changes, but recently (past 6 months), I have had to add a quart every second fillup. Last oil change, I changed to 10/40 synthetic blend, and it has been at least 6 fillups and I have not had to add oil. But last week, my car started to overheat, I brought it in, the radiator fluid was very low, the thermostat was changed, and I was told to keep an eye the fluid from now on, that perhaps the head gasket will need to be changed at some point.
6. The car has been extremely reliable, and I have only done routine maintenance to this point, brakes, tires, muffler, timing belt, water pump, tune-ups, no major engine work.
I use this for a commuter car, it has mostly highway miles. I would like it to last me another year, and my question is this: Should I consider fixing the head gasket, or will this open up a can of worms, since this car has such high mileage? And if I do go ahead with the repair, how much should it approximately cost? I thank you in advance for your expertise and helpful advice!
Oct 1, 2007 at 1:28 AM
BRUCE HUNT
  • 3,754 POSTS
Is that the side the A/C is on? You might listen to see if the knocking is coming from the A/C compressor. You might also check to make sure that the main pulley on the crankshaft is tight.
The overheating and coolant lose. I would be checking the radiator for any possible cracks that allow coolant to exit and prevent the cooling system from pressurizing.
A leak down test would be able to help pinpoint where any problems might be.
Oct 1, 2007 at 4:43 AM
