Take some time and try these things. They are free? Whoopee! Put some cardboard under the car to check for a leak. Take the plugs out of the vehicle and describe what they all look like.
Another great thing is to try a leak down test.
My suspicion is that you have compression and a compression test would probably support that. However, the loss of the oil and no detectable leaks only points to one area - bad oil rings. There is a smoke but the car is burning the oil pretty well. I would venture that the plugs are a little black and slightly oily on the end and the exhaust is running black. Look at the tailpipe and feel the inside. Is it black and slightly oily?
SPONSORED LINKS
Monday, July 9th, 2007 AT 9:13 AM
