1998 Honda Civic window malfunction
1998 HONDA CIVIC
143,000 MILES • 4 CYL • FWD • AUTOMATIC
GOODBADGERSMILK81
My right passenger window will only go up and my left rear driver's side window will not do anything. I checked all the fuses and switches. They all work on the driver's side connection and right rear connections. I installed a new regulator and motor on the passenger front side and it only went up as well. The odometer kicks in and out as well from time to time. It may be unrelated. Any ideas ?
Thanks
Aug 26, 2008 at 12:45 PM
KHLOW2008
  • 41,814 POSTS
Hi Goodbadgersmilk81,
The speedometer malfunctioning is due to a bad speed sensor.
If the windows all work from the master switch, then the individual door switch is faulty.
Aug 27, 2008 at 10:19 AM
