1998 Honda Civic Weird engine code
133,000 MILES • 4 CYL • 2WD • AUTOMATIC
PMP
  • 177 POSTS
hi, I had p0505 on a few weeks ago then got the iac replaced now everything is good. So i deleted the code today and io checked the freeze frame data on the scanner at autozone the obd 2 one somthin like that. I saw something under freeze fram for p0309 which is cylinder 9. This dont even make sense my car is 4 cylinder. The guy there thinks maybe a bad connection. What do you think?
also im gettin around 26-28 mpg is this right. I believe i should be gettin 30+ my old corolla got over 30 with a 1.8l engine this is a 1.6. I drive the car normal too and easy on the gas.
Sep 16, 2010 at 4:12 AM
WRENCHTECH
  • 20,758 POSTS
I would blame the Autozone equipment for that error. They don't exactly use quality professional equipment.
Sep 16, 2010 at 4:48 AM
