1998 Honda Civic Rough
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
PIGGY
I have been experiencing a rough idle only when the car is in gear and idle, like when sitting at a red light. I have changed everything, plugs, wires, distributor cap, rotor, etc. The rough idle stops when I either put the car in park or when I put it in neutral. It is annoying and shakes the steering wheel and everything. What could be the problem?
Thanks for your help
Aug 14, 2008 at 8:26 PM
2CARPRO JACK
  • 11,533 POSTS
At 150k I would suggest a good look at the motor mounts. When they wear out, they sag, causing the engine to no longer be insulated from the car, thus the vibration you feel
Aug 15, 2008 at 12:38 AM
COOLNESS23
yeah I have the same problem too.
Aug 17, 2008 at 6:42 PM
