1998 Honda Civic Problem putting care in reverse and brake
1998 HONDA CIVIC
ALISSAS3
Brakes problem
1998 Honda Civic Automatic
I have a '98 Honda Civic EX who's brake lights do not come on. Also if I want to put the car in reverse I have to put my key into the switch next to the gear shifter in order to back up. I was told that this was quite common with this model and that I needed a new brake pedal switch. Is this correct?
Sep 16, 2008 at 6:57 AM
KHLOW2008
  • 41,814 POSTS
Hi alissas3,
No, this is not common.
Check the brake fuse under hood first.
Sep 18, 2008 at 7:49 AM
ALISSAS3
Ok, I will check that as well. Thank you
Sep 19, 2008 at 12:59 AM
