1998 Honda Civic power window problem again
133,000 MILES • 4 CYL • 2WD • AUTOMATIC
PMP
  • 177 POSTS
Hello, I had my window regulator and motor replaced in the driver side door because the window was going off the track and when its all the way down you can slide the window around. Now a weeklater the same problem is back. My mechanic is saying the window track. I called up advanced auto and they dont sell it and they said it's very hard to get because its part of the door frame. Anyone can help me or know what the problem can be. I believe its the regulator again. Please help thank you.
Oct 2, 2010 at 9:19 AM
KHLOW2008
  • 41,812 POSTS
Hi pmp,
Have you checked the door glass run channel?
If there are too tight, they would restrict the glass movement and cause it to go off track.
Oct 3, 2010 at 7:50 AM
