1998 Honda Civic Power Steering Problem
JRTECHY
It takes a considerable effort to turn the wheel at parking lot speeds and when I am parrallel parking, as if there is no power steering assist. During cold starts, I would hear a high pitch whining coming potentially from the p/s pump area.
The P/S fiuld has been flushed and the P/S belt tension appears to be good. The tire pressure and alignment is fine. I took it to the dealer, but they couldn't find the problem.
I'm not sure where to start the diagnosis?
Aly
Feb 13, 2007 at 3:46 PM
BRUCE HUNT
  • 3,754 POSTS
When you increase the rpm does the steering improve? I suspect that the pump is failing.
Feb 15, 2007 at 2:38 AM
JRTECHY
The steering effort does not change with rpm. Is there anyway to perform a p/s pump test?
I want to be sure it's the pump and not the p/s rack.
Thanks.
Feb 15, 2007 at 1:28 PM
LOSTINMARS
  • 222 POSTS
i hope oem honda p/s fluid was used. if so i'd suspect the pump, as they are much more common. get a pressure check done to be sure though.
and if oem honda fluid wasn't used, be prepared to replace everything.
Feb 16, 2007 at 2:19 AM
