1998 Honda Civic over heating
ROD0001
  • 1998 HONDA CIVIC
  • 4 CYL
  • 145,000 MILES
I recently got a tune-up and now just a few weeks later my engine has started overheating. Isn't filling the engine coolant standard in a tune up? Also, what can I do right now to get home without overheating again? Should I put water in? Lastly, how long does it take before blowing a gasket or cracking the engine block?
Tuesday, June 10th, 2008 AT 8:17 AM
KHLOW2008
  • 41,814 POSTS
Hi rod0001,
Checking the coolant is standard for a maintenance service but is the cooling system leaking?
Yes water is better than mixing unknown coolants or anti freeze.
Blowing a gasket takes maybe 10 mins of excessive overheating and cracking a block is not easy unless you add water immediately when the engine stalls. It would be easier to crack the head.
Tuesday, June 10th, 2008 AT 12:25 PM
