1998 Honda Civic OBDII Code P0420
170,000 MILES • 4 CYL • FWD • AUTOMATIC
SEATAZZZ
  • 10 POSTS
I recently replaced the radiator, hoses, thermostat, plugs, and wires. Car was ran a few times with misfiring plug, now I get the CEL with code P0420 (catalyst operating below threshold). I know I can replace the cat for about $200, but I won't have the money for a month or two and am wondering if car is safe to drive? There is NO rotten egg smell, engine performs just fine with no misfires or loss of power. Gas mileage is fine too. But I need this car for work. Another question: worst case scenario, if cat completely fails, what happens? Also, after many Google searches came across the "spark plug defouler fix" and am wondering if this is legit? Will my car pass emissions? Don't have to have that done until 2012. Any answers or suggestions welcome, thanks so much!!!
Aug 27, 2010 at 1:06 PM
  • 31,937 POSTS
Hi there,
I would be checking the O2 sensors first, but if the cat is failing, what you may find is that it will start to glow red hot and also if it breaks up it can block the exhaust and very poor performance will result, if just codes for now, have the 02 sensors tested first.
mark (mhpautos)
Aug 27, 2010 at 1:15 PM
SEATAZZZ
  • 10 POSTS
Is there a visual check for the O2 sensors? Or would I have to take the chance, buy a new one, and hope the code doesn't throw again? According to Autozone's OBD scanner, the only code it has is the P0420.
Aug 27, 2010 at 3:10 PM
  • 31,937 POSTS
There is no suitable visual test for the sensor, a mechanic will have to test it on a live date read oscilloscope.
mark (mhpautos)
Aug 27, 2010 at 5:42 PM
MADMIKE1735
  • 951 POSTS
a p0420 is a cat efficiency code.... most "dishonest" garages will sell you a cat from the start.... heres how your sytem works... you have an upstream o2 sensor (before cat) and a downstream o2 (after cat) they throw signals to one another, and that lets the computer know whether its running rich or lean... if one goes bad however, it does have the possibility of causing a cat to go bad.... before dropping the $500 on a cat, have all your o2 sensors replaced.... if the dreaded p0420 comes back, then you gotta bite the bullet and buy a cat... 75% of the time its only an o2.
Aug 28, 2010 at 3:24 PM
MADMIKE1735
  • 951 POSTS
also, if the cat is clogged, then it mean it ran way lean and melted.... in which case you will have bad engine performance, and if you look under the car ( most noticeable at night) the cat will be glowing cherry red... if thats the case, then you will need to replace the cat... hope this helps, keep us updated.
Aug 28, 2010 at 3:28 PM
SEATAZZZ
  • 10 POSTS
Have another silly question--when the radiator blew, lots of gunk and nasty gummy antifreeze & tranny fluid blew all over the front of the engine, including down the front of the exhaust manifold. The connector for the downstream O2 sensor is covered in black gunk. I cleaned up the manifold but am leery of cleaning the connectors--saw some stuff at O'Reillys called electrical parts cleaner, will that get rid of the gunk? And could a dirty connector be sending a false signal?
Aug 29, 2010 at 3:40 AM
  • 31,937 POSTS
If the actual terminal of the connector is dirty, corroded or loose, you will get a bad reading, the out side is not an issue, cleaning the terminals won't hurt, it would be a good thing to check them.
Mark (mhpautos)
Aug 29, 2010 at 10:14 AM
