1998 Honda Civic LX manual transmission
About 3 years ago during the summer I drove over a railroad track with the AC on. I didn't hit the tracks hard, but they are elevated a bit so it was enough for a light and normal jostle. I heard a reasonably loud clunk-clunk noise. It wasn't the bump noise of the track, but a different noise just milliseconds after. From that point on the AC was dead. In my civic, when I normally turn on the AC when it works properly, you can feel the compressor / clutch engage and the load on the engine. Now, I can still hit the AC button on the dash and the little green light in it will come on, but the ac never engages and I just get ambient temperature air blowing. Just today, I decided to do something about it. I tested the pressure and the refrigerant is properly pressurizing the system. No leaks. When the car runs, I can see the belt rotating fine over the compressor wheel and that isn't seized up. I checked the related fuses and they are OK. I fed a positive wire I rigged up to the wire coming off the compressor and I get a small spark, but the clutch does not engage. Now I'm thinking it is the clutch or the compressor or both. I'm guessing that is what I need to change. I see it online for auction for about $250 delivered with a dryer and o rings and oil. So, A) should I just replace this next. B) I assume legally I need to get it evacuated, so that's OK. C) after I put the parts back on and if I did it right, do I need to just go to a pro and get it evacuated and charged and then I'm done? If I can get away with not depressurizing the system and just change a clutch, that would be great but I don't know for sure if it will solve the problem. Thanks.
One more thing. I can't tell if the inner part of the clutch is spinning or not due to the location of the compressor. It's pretty far down there and up close to the front left wheel. If necessary, I guess I can pull the wheel off and start pealing back the shrouding between the wheel and the engine compartment.
Jun 20, 2020 at 4:00 AM
(Merged)
