1998 Honda Civic LIGHTS AND SPEEDOMETER
146,000 MILES • 4 CYL • 2WD • MANUAL
KJ88
speedometer jumps around. only once in a while the lights will stop flicking but the speedometer never stops jumping. how do i stop this?
Jan 25, 2009 at 3:37 PM
KHLOW2008
  • 41,812 POSTS
Hi KJ88,
The speedometer jumping around could be due to a faulty speed sensor located on the trans axle differential housing below the thermostat housing. It could also be related to the lights flickering and I would suggest rectifying the the lights flickering first.
Possible causes are:
1. Bad body ground. check all grounds at front fender inner side behind headlights.
2. Alternator. Check the charging rate, ensure crankshaft pulley harmonic balancer is not faulty ( if equipped) before testing charging rate.
Apr 7, 2021 at 5:56 AM
