1998 Honda Civic Issues with air conditioning/heater
107,000 MILES • 4 CYL • 2WD • MANUAL
CHOPLARUSKI
I was having trouble with my heater in the winter. Originally the heater had only been working on the high heat settings, which I assumed was a blown resistor. Eventually it stopped working entirely. I got it checked out, they replaced the resistor, everything seemed to be ok at first.
I noticed, however, that the heater/ac was now blowing out maybe half of what it used to. Also, every so often there is a noise that sounds a little bit like plastic shaking or blowing. About 4 months went by without a problem. A couple days ago the whole AC stopped working again. This time however, if I leave it running for about 5 minutes the AC will suddenly start working again. So I'm not sure if something is blown or what. Is something in there clogging it so even though it might be "technically working", nothing is coming out or is it something else?
Apr 15, 2009 at 12:01 PM
KHLOW2008
  • 41,812 POSTS
Hi choplaruski,
Seems the blower motor is giving you hints it is about to retire itself.
When blower don't work, give the housing behind the glove box some banging with your hands and if it starts working, time to get a new motor.
Apr 19, 2009 at 3:42 AM
