1998 Honda Civic 4 cyl Front Wheel Drive Manual 210K miles
Problem started with faulty HV contact spring on ignition coil. Car stalled out, so was diagnosed, and replaced cap, rotor, plug wires, plugs & coil. Car ran well for a while, then developed cranking issues that have progressively worsened. Starter turns engine over and spins just fine. Pumping the 'gas' pedal eventually causes the engine to start firing slightly. Continued cranking (crank/off/crank/off) eventually results in sudden flooding, and gas vapor cloud emerging from air cleaner. A couple more cranks, and the engine starts, runs roughly, then begins to heat up, and after 5-10 miles, runs better, but you can feel some hesitation when trying to drive at a constant speed. "Aha, fuel delivery issue!" New fuel pressure regulator, fuel pump & strainer. No solution. Also NO codes on OBD port either, having had it checked 3 times. Have service manual, not sure which way to jump or what to replace next. Thanks!
SPONSORED LINKS
Tuesday, October 6th, 2009 AT 6:06 PM
