1998 Honda Civic engine codes
149,000 MILES • 4 CYL • FWD • AUTOMATIC
AN2NY0830
  • 13 POSTS
theres a check engine on my car and i had it diagnosed and its findings are engine code 1361 and engine code 1399 what are this codes and how do i fix them... just had it tuned new plugs,coils,rotor distributor cap
Feb 19, 2010 at 1:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P1361 : CKP/TDC/CYP Sensor
The CKP/TDC/CYP sensor is built into the distributor and is serviced by replacing the distributor ignition housing.
DTC P1399 : Manufactures Control Ignition System OR Misfire
Replacing distributor ignition housing will also fix the second trouble code as both are related.
Feb 19, 2010 at 1:44 PM
