engine block drain plug
EVOLUTION09
  • 24 POSTS
Engine Cooling problem 4 cyl Front Wheel Drive Automatic 124000 miles
i want to flush my coolant from my engine block, but i don't know where is the drain plug on my engine block, so can someone help me locate the drain plug.thank you
Sep 20, 2010 at 9:02 PM
BENCHRISMAN
It's to the left of the oil filter. Most Honda service techs don't recommend removing it though. You'll find very little comes out and its a bugger to remove and then re-torque upon replacement. May try draining the system (via radiator drain cock), take out your thermostat, fill back up with distilled water, run the car a minute, drain it. Repeat. Once it drains clear. Reinstall stat, refill with coolant, bleed the air, top off coolant. Done.
Aug 9, 2012 at 6:08 PM
