1998 Honda Civic electrical
92,000 MILES • 4 CYL • 2WD • MANUAL
JAYJAY91
can a spark plug burn your computer chip if you have cheap spark plug on a msd ignition n high power motor
Jun 15, 2008 at 8:46 PM
KHLOW2008
  • 41,812 POSTS
Hi jayjay91,
The spark plugs are not directly connected to the ECU so should not.
Jun 16, 2008 at 1:00 AM
JAYJAY91
can u predict why the computer chip alway burn out when i turn the car on
Jun 18, 2008 at 6:33 PM
KHLOW2008
  • 41,812 POSTS
Hi jayjay91,
Predictions are not for mechanics, we analyse and try to come to a conclusion before giving out any advise.
If the ECM gets burnt while cranking, or with ignition on, there should be a shorting somewhere.
A loose ground would also cause power surge to it.
This is going to be a nightmare, to pinpoint the fault would not be easy.
Look around all wirings and see if any are bare.
Before this, did you do anything to the car? If you did, back track and see where you have gone wrong.
When did this start happening?
Jun 19, 2008 at 1:14 AM
