1998 Honda Civic drivers side lock problem?
TVIN
Electrical problem
1998 Honda Civic
I have a Civic and i have to use the keyless fob to lock my doors. when im inside the car i cannot lock my drivers door by pushing in the lock knob. ill push and it goes in a little and when i get out of my car and check its still unlocked. but if i press in the knob on the passangers side it locks the door. can you help me please. i would like to do this DYI so if you know where i could get the parts that would be great.
Nov 11, 2008 at 4:00 PM
KHLOW2008
  • 41,812 POSTS
Hi tvin,
Since the actuator is working, I suspect this is a linkage problem that could be solved by some adjustment.
Remove the door trim and check which part is causing the restricted movement of the lock knob. Some lubrication might help.
Nov 20, 2008 at 6:59 AM
