code P0108
85,000 MILES • 4 CYL • 2WD • MANUAL
OILW30
Took my Civic in and they said I need a new MAP sensor. The check engine light had come on and it returned code P0108. They also said I need a new "adapter harness," which seems to be very expensive. Does anybody have any idea what this?
Jul 2, 2008 at 7:41 AM
KHLOW2008
  • 41,812 POSTS
Hi oilw30,
Never heard of such a thing.
Get a throttle body assy from the scrap yard, it comes with the MAP and should not be expensive.
Honda MAP seldom fails, could be a wiring problem. Get a second opinion.
Jul 3, 2008 at 1:25 AM
OILW30
Thanks. I took it to a second guy and he did a new diagnostic. He said it was the MAP sensor too and replaced it for about 1/5 the price that the dealer mechanic wanted. Hopefully that's the end of my troubles.
The car still seems to be wobbling a bit, like it's idling high, but I think it's done that for a while and it comes and goes.
Jul 7, 2008 at 6:35 AM
KHLOW2008
  • 41,812 POSTS
Hi oilw30,
Irregular idling could be due to idle adjust not correct, insufficient coolant, clogged coolant hose to IAC and clogged IAC or throttle body.
Jul 7, 2008 at 11:53 PM
