1998 Honda Civic Brake Drum
1998 HONDA CIVIC
120,300 MILES • 4 CYL • FWD • MANUAL
MY KUMAG
The break drum is stocked. How to remove the break drum.
Jul 27, 2008 at 6:57 AM
KHLOW2008
  • 41,814 POSTS
Hi my kumag,
After removal of wheels, brake drum can come off if you bang it or use 2 pcs of m8 bolts to pull it out.You can get it off together with the hub central bearing by removing the nut. If the brake linings are getting in the way, you need to release the adjusting pushrod through the backing plate slot. This video will show you how.
https://youtu.be/UV0kfP17Co0
Mar 16, 2021 at 4:23 AM
