Hi my kumag,
After removal of wheels, brake drum can come off if you bang it or use 2 pcs of m8 bolts to pull it out.You can get it off together with the hub central bearing by removing the nut. If the brake linings are getting in the way, you need to release the adjusting pushrod through the backing plate slot. This video will show you how.
https://youtu.be/UV0kfP17Co0
Mar 16, 2021 at 4:23 AM
