1998 Honda Civic Bad whining noise
286,000 MILES • 4 CYL • FWD • MANUAL
JOSEPHNOEL
Hello I own a 98 honda civic and I just recently developed a weird grinding/whinding sound from my transmission but it almost seems like it is in between where the axle meets the transmission and when i turn left it makes a aweful grinding sound from that spot. I ruled out wheel bearings and tires anything of that sort. And the boots on my cv joints are in good shape So maybe do you think it could be a bad bearing from inside my transmission case where the shaft sits?
Jul 12, 2010 at 2:37 PM
F4I_GUY
  • 3,302 POSTS
Sounds like the differential itself has failed.
The transmission is going to need to be replaced or overhauled.
Jul 13, 2010 at 11:43 AM
