1998 Honda Civic air conditioning question
131,000 MILES • 4 CYL • 2WD • AUTOMATIC
PMP
  • 177 POSTS
Hello, i just bought this car its a real nice car. The a/c has a small problem. It blows hard all the time firast of all. Second it stays cold for like a minute then starts turning warmer not hot but like cool. Does this sound like freon? also when the ac is on the highest setting the blower motor seems to vibrate. Thank you
Aug 22, 2010 at 3:30 AM
KHLOW2008
  • 41,812 POSTS
Hi pmp,
If the A/C has automatic climate control mode, and is turned to that, it would blow hard at first.
If the blower is vibrating at the highest mode, it could be a faulty blower motor or its blades are out of balance. Could be a missing blade.
When A/c blowers warmer, check the temperature control settings.
Check if the A/C compressor ia engaging.
If it is freon, it would not blow cold at all.
Get the low and high pressure readings so we can understand what could be wrong.
Aug 22, 2010 at 4:14 AM
PMP
  • 177 POSTS
hey, well the air was cool not cold. and the compreszsor is going on i saw the idle on the dash move when i turned it on.
Aug 22, 2010 at 5:32 AM
KHLOW2008
  • 41,812 POSTS
It could be low on freon and the pressure readings would confrim if that is the problem.
Aug 22, 2010 at 5:43 AM
PMP
  • 177 POSTS
[quote:4cb3639cfe="pmp"]hey, well the air was cool not cold. and the compreszsor is going on i saw the idle on the dash move when i turned it on.[/quote:4cb3639cfe]
i just checked it again its not cold its liek out side air but the compressor seems like it kicks o i see the rpm move when i press the button
Aug 22, 2010 at 5:50 AM
KHLOW2008
  • 41,812 POSTS
If you are not going to get the low and high pressure readings, I would not be able to help you.
Aug 23, 2010 at 3:30 AM
