Hi pmp,
If the A/C has automatic climate control mode, and is turned to that, it would blow hard at first.
If the blower is vibrating at the highest mode, it could be a faulty blower motor or its blades are out of balance. Could be a missing blade.
When A/c blowers warmer, check the temperature control settings.
Check if the A/C compressor ia engaging.
If it is freon, it would not blow cold at all.
Get the low and high pressure readings so we can understand what could be wrong.
SPONSORED LINKS
Sunday, August 22nd, 2010 AT 11:14 AM
