Hi kenpc,
The blower air flow problem should be due to the venting system. Check if the vent cables are properly adjusted.
If you have no cooling problem, it is normal for some condensation to collect on the low pressure pipes.
Improper gear shifting when compressor is engaged could be due to engine lack of power problem. Check if the ignition timing is correct.
SPONSORED LINKS
Thursday, July 31st, 2008 AT 1:42 PM
