To: merlin2021
Posted: Sun Feb 10, 2008 9:52 am
Subject: AC failure
The compressor seized. The clutch seemed to engage and disengage properly.
So if the system has a filter on it to remove any debris I shouldn't have to replace the the evaporator or the condenser?
To answer your PM: If your system has a filter on it you would be real lucky? The filter is what YOU must put in the line after flushing and before filling with new R134a If no filter was on the system, you must replace these other parts, or metal shavings may ruin a new compressor!
Feb 10, 2008 at 1:10 AM
