1997 Honda Civic
ELCACHANILLA
  • 1997 HONDA CIVIC
  • 4 CYL
  • FWD
  • 160,000 MILES
Quiero saber como recargo mi aire acondicionado despues de haber cambiado mi ac condenser porque ni el compresor prende porque el sistema esta vacio
Tuesday, August 12th, 2008 AT 10:58 PM
  • 31,937 POSTS
Hi there,
You will have to get the system vacuumed down, and make sure that it holds the vacuum as this is the test for a leaking system. When this has been done the refrigerant can be added to the system, it is a good idea to use the correct gauge set so you don't under or over charge the system.
Mark (mhpautos)
Wednesday, August 13th, 2008 AT 12:18 AM
