Hi there,
If this noise goes as you slowly press the clutch the clutch thrust bearing could be at fault, can you feel and vibration through the clutch pedal? Go get a mechanic to test it, he will be able to tell just by pressing the clutch a few times, this to repair will need the transmission removed.
Mark (mhpautos)
SPONSORED LINKS
Monday, February 2nd, 2009 AT 4:27 PM
