2005 Honda Civic Clutch noises
2005 HONDA CIVIC
140,000 MILES • 4 CYL • FWD • MANUAL
BILLING10
Hi i have an 05 civic manual and when the car is in neutral just sitting there is a nise almost like spinning or rattling but when i push in the clutch the noise goes away also when im in first gear there is a noise that comes in at about 2500 rpms if u have any ideas that would be awesome thank you
May 10, 2010 at 7:28 PM
  • 31,937 POSTS
Hi there,
This sounds like a clutch thrust bearing , as when you press in the clutch the bearing is loaded up and goes quiet, this a fairly common problem.
Mark (mhpautos)
May 10, 2010 at 7:44 PM
NIROUME
Hi, I have got exactly the same problem, I called a garage earlier on and they told me that instead of the clutch release bearings that it sounded like the Gearbox gearing needed changing....not good, as this is a lot more expensive to fix. Well, I will get it check properly tomorrow and I will see and will let you know.
Regards, Noemi
May 19, 2010 at 7:38 AM
  • 31,937 POSTS
An input shaft bearing will be noise in gear and in neutral, less so with the clutch pressed, as then the clutch has disengaged and there is no drive through that bearing.
Mark (mhpautos)
May 19, 2010 at 10:25 AM
