Stereo radio light stays on
HASTINGSSFD
Stereo radio light stays on after the car is shut off and headlamp switch also is turned off.
Please help.
Jan 30, 2006 at 9:13 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify whether only the light or the radio’s audio also remained on, whether the unit was factory-installed or aftermarket, and whether the light eventually went out.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
JELLED21
  • 10 POSTS
All I will say/ask is first...Is the stereo aftermarket, and was it professionally installed? If so then I would bring it back, they wired up the power to the wrong area, and second...Is the radio still on completely or just the light. And if it is factory, then a good inexpensive radio isn't hard to find and plus they seem to have a better sound anyway. Hope that helps a little
Jan 30, 2006 at 3:29 PM
Discussion summary
The owner reported that the stereo’s light stayed on after the car and headlamp switch were turned off. The thread did not clarify whether the radio itself also remained on.
Reported outcome: No confirmed diagnosis, completed repair or resolution was reported.
The radio configuration and installation history were not supplied. The reply’s suggestion of incorrect wiring was not supported by inspection findings and does not establish installation fault.
Read the original discussion
