1997 Honda Civic Windshield Washer
1997 HONDA CIVIC
98,200 MILES • 4 CYL • 2WD • AUTOMATIC
STEVELOW1
  • 7 POSTS
Whenever the windshield washer is used on this car it streaks the windshield, even when using new fresh windshield washer fluid. I think that maybe after 12 years the fluid reservoir and/or rubber tubing is contaminated but of course I'm not sure. Should I replace everything or is there some other solution? It's very annoying to my 20 year old daughter who drives the car. Maybe a decontamination liquid of some sort.
Thanks for your help.
Aug 11, 2009 at 2:15 AM
BUDDYCRAIGG
  • 2,262 POSTS
I've had this when someone put antifreeze in the tank before.
I had to keep washing the tank out with Dawn brand dish soap and water.
and then clean the windshield with rubbing alcohol.
Aug 11, 2009 at 3:25 AM
STEVELOW1
  • 7 POSTS
Thanks for your help. But I need clarification. How will I get the cleaning liquid out? Do I just put the Dawn dishwasher detergent and water into the washer reservoir and squirt it out using the windshield washer from inside the car or do I somehow remove the reservoir and clean it out that way? Please advise.
I never would have thought of using rubbing alcohol on the windshield. Will do asap.
Aug 11, 2009 at 4:17 AM
BUDDYCRAIGG
  • 2,262 POSTS
If you cant remove the tank easily then take your garden hose and stick it in the opening for the tank as far as you can, and just let it run for a while.
Aug 11, 2009 at 12:05 PM
STEVELOW1
  • 7 POSTS
I understand. Thanks.
Aug 12, 2009 at 12:17 AM
