1997 Honda Civic TUNE UP PROBLEM
120,000 MILES • 4 CYL • FWD • MANUAL
ERNIEK01
I CHANGED THE PLUGS , WIRES , CAP AND ROTOR AND NOW NO SPARK , THE CAR WAS RUNNING PRETTY GOOD WHEN I STARTED THE JOB I PUT BACK THE OLD CAP AND WIRES NOTHING I ALSO HELD A NEW AND OLD PLUG TO GROUND WHILE TURNING ENGINE NO SPARK
Oct 3, 2009 at 9:00 AM
KHLOW2008
  • 41,812 POSTS
Hi erniek01,
Thank you for the donation.
Apart from those mentioned, was any other work performed?
Did you test the Black/Yellow wire at distributor for voltage with ignition turned ON and while cranking?
Note if the Check Engine Light goes off after 2 seconds when ignition switch is turned ON.
Oct 3, 2009 at 2:54 PM
