Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Civic
Drivetrain
Transmission
Symptoms
Slip
1997 Honda Civic transmission slip
1997 HONDA CIVIC
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
FRANCISCO MUNDO
MEMBER
1 POST
when the car gets into 1st gear it sometimes slip, not always. every other gear works fine.
Dec 22, 2008 at 12:44 AM
KHLOW2008
Experienced Mechanic
Hi Francisco,
Thank you for the donation.
Does it happen only when cold or after warming up?
Is it slow to engage 1st gear?
Did you check the trans fluid level?
What is the color of the fluid?
For 1st gear to slip, it usually means the trans is failing.
Dec 22, 2008 at 1:57 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
