Hi there!
I just replaced the overflow tank as it was disgustingly dirty, the cap for the tank and the internal hose. I notice a bit of leak on the hose leading from the rad (at the reservoir tank), and I think that this is why it's happening (a vacuum seal is not being properly made for the rad to suck fluid back in). Can I get away with a clamp, or do I need a new hose? I have a clamp on hand, a hose I will have to go and get. Thanks!
Ok, I just replaced the hose... I'll let you know if that's it. But if it isn't, what else could it be? I could only think of the Thermostat?
Feb 7, 2009 at 4:19 AM
