When starting after a couple days of not driving, my car is difficult to start and jugs significantly when initially started. Once warmed up, it runs better, but you can still notice a slight jugs at idle. I ran a diagnostics and 3 cylinders are miss firing. I replaced the plugs and wires, but it did not help. What do you think the problem is? I recently pumped gas into it that contained a significant amount of water. It caused my car to die. I had the tank drained, and the fuel filter and all injectors replaced. Maybe a couple hundred miles later and this started. Could this still be part of my problem?
Jul 31, 2008 at 5:47 AM
