1997 Honda Civic Misfire
GUATE2006
Engine Mechanical problem
1997 Honda Civic 4 cyl Front Wheel Drive Automatic
I have a problem with my car I did the headgasket the other day. I set up the everthing as suppost to even the timing belt set up n now I got misfires in all 4 cylinders. I changed the rotor cap, ignition rotor n cables n stills doing the same thing. Can u give me any advice on how to fix it. Thank you
Nov 11, 2009 at 9:44 PM
BMRFIXIT
  • 19,053 POSTS
Check the injector
or maybe switch it with another looking for the code to switch with the injector
do a compression test
Nov 11, 2009 at 10:00 PM
