Hi Imran_Ahmed,
Driving around might not solve the problem because most probably the Intake Air Control valve is stuck and not closing enough to lower the idling speed.
You need to try to get the IAC valve moving, try spraying some carb spray into the throttle body lower air passage to free it up.
Check if the coolant in radiator is sufficient and the hoses to the IAC valve is not clogged.
SPONSORED LINKS
Friday, October 17th, 2008 AT 2:00 PM
