Hi phanqkhoi,
P0700 means there is at least one trouble codes with the transmission and in this case it is P0715.
DTC P0715/15: MAINSHAFT SPEED SENSOR
NOTE:
DTC P0715 doesn't always mean an electrical problem in mainshaft speed sensor or circuit. This DTC can also be caused by a mechanical problem in transaxle.
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
© 2008 Mitchell Repair Information Co., LLC.
Page 1 of 1
DIAGNOSIS - A4RA, B4RA & M4RA -1997 Honda Civic EX
28/3/2010
http://www.ondemand5.com/mric/common/asp/printart.aspx
Mar 27, 2010 at 6:40 PM
