1997 Honda Civic 3rd and 4th gear issues
210,000 MILES • 4 CYL • FWD • MANUAL
LOGANSEVEN7
Purchased this honda about 9 months ago, just started having issues putting it in 3rd and 4th gear.
Third gear is hard getting in and out of , No grinding sound. But 4th gear has a Grinding gear sound when trying to put it in gear.
I have tryied Double clutching to put it in gear easier, but it doesn't make a difference.
Can put it in 1st, 2nd, 5th and Reverse with No problems at all.
Any Idea what could be the issue??
thanks
Jul 18, 2010 at 8:15 AM
KHLOW2008
  • 41,812 POSTS
Hi loganseven7,
Symptoms indicates the 3rd/4th synchrohub is failing and would require rebuilding soon.
If you had replaced the gear oil prior to this occurring, check if the correct grade had been used.
Jul 19, 2010 at 3:34 AM
